I have a 51" TO-30 that has the 12 volt conv. kit , purchased from this site , Neg. ground. with ballast resistor , coil with condenser and dist. w/ points. She keeps stalling after a minute or 2 when first started. Then sometimes will run fine. Getting gas , but stalling / shuts off like someone turned the key off. I have replaced the key switch as some have requested but no luck. I'm going to change over to a electronic ignition and a new coil , purchased from this site , and the question is , do I still need to use the ballast resisitor after new coil and ignition ?
If it doesn't work I'll go back to 6 volt positive ground !
Comments welcome , Thanks
