Tom Bowman
I had to cut off the mounting bolt in order to remove the worklight from the TO-20. I think I've found the correct replacement bolt, but I can't see how to remove the remaining part of the bolt from the socket. Here's a photo of the inside of the socket (the bolt head is the round thing with a hole in the center):
I thought I could pry up that clip to get enough clearance to slip out the head of the bolt, but the clip is too stiff, and not at all "springy". (I could probably bend it, but I'd never get it bent back down.)
I was glad to find the hollow bolt: now I just need a switch, and a bulb, and to clean it up, and paint it...
