TractorLinks.com
Show Parts for Model:
Re: This is what happens when your tractor sits too long
Jason S.
08-24-2014 08:16:56
Tony I think I have a Gordon Lighfoot 8 track here that you can have next time your out this way...lol. I thought I would add an update on the motor. The crank I believe will be ok with just a cleaning and polish. It has already been turned .030. It must have been done many many years ago though because the bearings are marked Z120 .030! The bearings do not show any wear. My biggest concern is the cam journals in the block,but worse case scenario I can have the block bored and cam bearings installed. I have two extra camshafts I can use for this motor. I have another Z120 engine with a good camshaft and I also have a MF 35 engine with a good cam shaft. I do know they changed the camshaft in the 35's about three times so I don't know which one this one is. I will have to measure it I suppose. My preference would be to have the camshaft that was used in the Z129 and early Z134 engines because they have better valve timing to build more torque than the Z120 camshafts did.
