Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TEO20 front axle help please.
Tony in Mass.
08-24-2014 06:13:10
Sounds like something else is bent too. If getting the radiator out of the way works, do it anyway. Sounds like the axles have to be compared to a not buggered up axle. The holes and angles are designed to not hit the rad, so you got to measure things up again. good luck.
Bruce(OR)
08-24-2014 07:38:48
 Re: TEO20 front axle help please. in reply to Tony in Mass., 08-24-2014 06:13:10
I am aware that Ford ran different length radius rods on his machines. I suspect Harry did the same.
John(UK) might be able to add some knowledge to this. I am in Portland, Ore and should have a set of rods from a TO-20 and digging out my 1973 era parts book...Survey says...part number 180 351 M91
2 EA used on TO-30, TO-20, TE-20, TE-A 20.
nce you get this all together, add some (real) copper pennys behind the radius caps to remove wear. You get to research what yeras had a better copper content.
