TractorLinks.com
Show Parts for Model:
Re: i am in and i am guessing this is not good....35hyd
John(UK)
08-21-2014 06:11:42
Remove the LEFT side round inspection port, the one with the PTO Lever, you can see more through that one. No you don't need the PTO engaged to drive the Pump. You can look in through the port to see just where the oil is leaking from. From how you describe it, (leaking at the front and blowing back) it is most likely the "O" rings on the High pressure pipe from the Pump up to the top and you get to that easy enough by removing the square plate just forward of the seat that is held on with 2 bolts. make sure the hydraulics are lowered before you remove it. Lift the plate straight up and replace the "O" rings at both ends. These often leak and even if it isn't showing a leak just now, well worth changing them. The only other thing that can leak in the top is the Lift Cylinder and there is an "O" ring under that, this means that the top cover need to come off. If you need more written info about all this, email me and I will send it to you.. John(UK).. fergusontractors@hotmail.com
