s19438
is there much difference between 1st gear high range and 3rd gear low range and where would an application show the difference ?
thanks.
First gear high is quite a bit higher than 3rd gear low. I don't know by how much but there are some things I can do in 3rd low that I can't do in 1st high.
1957 TO35 gas:
I plow in third low pulling 3-12"
My uncle could plow in first high pulling 2-14's with MF35.
So there many be some differences in hp and gearing of the different models.
Also difference in ground hardness that is being turned.
I have used a 5ft tiller with my tractor and it did a great job in the lower gears, second low.
The little TO35 is a fine little tractor for the jobs it was designed to do.
Good diff between the two. I'd have to go check the tractormeter to see the actual speed diff, but i think it's about 1-1.5mph..
Most of my tractor time is brush hogging with a 5ft hog. I run 1H if I'm just clipping off a pasture. 3L if it's a good foot. 2L if it's up to the hood. 1L if it's brush to the hood.
Here is a table I created a while ago showing the speeds of a few different tractors. I got these numbers mostly from the operators manuals.
Dan
<table width="800" border="2"><th colspan="6">Comparison of ground speed MPH at 1500 RPM</th><tr align="center"><td>gear</td><td>Ford 9/2N</td><td>Ford 8N</td><td>Jubilee
NAA</td><td>Ferguson
TO20/TO30</td><td>Ferguson TO35/F40
Massey Ferguson MF35/MF50</td></tr><tr align="center"><td>1st</td><td>2.63</td><td>2.77</td><td>2.77</td><td>2.58</td><td>Low&nbsp; .97&nbsp;&nbsp;&nbsp;High 3.91</td></tr><tr align="center"><td>2nd</td><td>3.5</td><td>3.56</td><td>3.56</td><td>3.56</td><td>Low 1.46&nbsp;&nbsp;&nbsp;High 5.86</td></tr><tr align="center"><td>3rd</td><td>8</td><td>4.9</td><td>4.9</td><td>4.9</td><td>Low 2.69&nbsp;&nbsp;&nbsp;High 10.76</td></tr><tr align="center"><td>4th</td><td>---</td><td>10.23</td><td>10.23</td><td>10.24</td><td>---</td><tr align="center"><td>5th</td><td>---</td><td>---</td><td>---</td><td>---</td><td>---</td></tr><tr align="center"><td>rev</td><td>2.87</td><td>4.55</td><td>3.2</td><td>2.98</td><td>Low 1.31&nbsp;&nbsp;&nbsp;High 5.22</td></tr></table>
