Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TE20 hydraulic problem
Graham in France
08-17-2014 08:27:00
Thanks Charles, great tip!
Anyway, here's the update. I adjusted the clutch as you suggested, as you said it took a couple of goes to get it right.
I took off the pto so the blades wouldn't turn and started the engine with the hydraulic lever engaged (clutch down.)
I could then raise the mower and back out the barn - hooray!
I then took the hydraulic lever off, and tried to put it in again but it made the same grating noise as before so I'm back to square one. At least I know I can start it with hydraulics to use the machine.
One last thing, I found it wouldn't go into reverse gear. I had to remove the gear lever and click the selector with a screwdriver to go into reverse and back again. I replaced the gear lever and itselected ok.Don't suppose that might have anything to do with it?
Thanks again
