bigger wheels tea20
pcp20us
Hi.
Want to get better wheels on the front end. currently i have the standard chees cutters.
It looks like the diesel ( tef20?) have the better rims, think they are the 4.50 x 16 rims and chunker tyres? is this correct.
Read on old holden website that some guy put holden front hubs in the tea20 then used hoden rims.
Anyone done this or got some advice on a cheap solution.
also having trouble find the hydrualic lift lever lock, anyone know where to get one in Australia.
cheers
The 6.00x16 tire was optional for most of the Ferguson tractors. You can buy brand new 4.50x16 rims on eBay for less than $70.00 a piece and they ship worldwide. I'm not sure what you are calling the hydraulic lift lever lock. You mean the wedge and chain assembly that locks the control lever in place so you can't raise the lift while using the stay arms?
Watch the back side of wheel "offset" on any front wheel replacement. I have one that is 4" and gives correct clearance to the upper spindle arm attachment point, and the other is 4.5" and will make contact with 6x16 tire sidewall. I am going to replace this wheel with the correct 4" offset type, asap, using spacers now but not happy with this situation.
Fx
(quoted from post at 20:50:05 08/11/14) The 6.00x16 You mean the wedge and chain assembly that locks the control lever in place so you can't raise the lift while using the stay arms?
I mean the Stop, Hydraulic Quadrant Lever
http://www.fixthatferguson.com/index.php?main_page=product_info&cPath=2_9_32&products_id=854
19 inch wheels were standard, 16 inch wheels were an option for all Grey Fergy tractors.
The 16 inch wheels and Lever Stop are available from most tractor dealers that are BareCo or Sparex Dealers. Call [b:ec4c80b529]MD Machinery in Melbourne[/b:ec4c80b529] as they seem to be able to supply almost anything Grey Fergy. They also sell via EBay.
You will find the 16 inch BareCo wheels here: http://www.bareco.com.au/files-masseY2001-mf4
16 inch Sparex wheel: http://v2.ca-en.sparex.com/ItemDetails/ItemDetails.aspx?ItemNumber=40286
Lever stop from the UK - but a bit expensive: http://www.silverfoxtractorspares.com/ferguson-te20-tractor-hydraulic-lever-quadrant-stop-2nd-option-21077-p.asp
Here is a cheaper lever stop: http://www.fixthatferguson.com/index.php?main_page=index&cPath=2_9_32
Google is your friend! :lol:
Bob in Queensland
hi bob.
thanks, I found the fix it fergie site for the lever stop, put at roughly $50 for postage it was a tad over the top.
Hi Bob.
No bare co do not do em and dont think sparex?? do them either. hard things to find.
I did find one second hand which was lucky..
Bob do you know an aftermarket colour code etc for the fergie grey paint.
Cheers
