I need advice if anyone has repaired the seals on both the diesel fuel shut off shaft and also the throttle/governor shaft. Both are seriously leaking from the top of the CAV fuel pressure pump.
Also leaking is the large nut located on bottom rear of this pump. The Ferguson parts manual only shows the top two shafts listed as "seal" part#1 012 695 m1. No reference to the nut on bottom that appears to be a drain plug, as nothing attaches to it.
Any thoughts or advice greatly appreciated.
Fx
Fx
