Just finished overhall to20 / broke a oil pump gear & lost a rod bearing / new oil pump rebuild / new rod bearings / mains were good & plastice gage ok / put 1 shim in PSI spring / runns fine
oil PSI is 32 to 36 to high ??
wat u think ok ?
The correct oil pressure for these Engines is:-
20 - 30psi @2200rpm and 15psi @ idle speed 450rpm
I would think that pressure will drop slightly shortly when it has run a while, I would leave it. John(UK) fergusontractors@{hotmail.com
