Hi All
Have been using the teat20 for about a month now.
today i had the slasher on so used the pto for the first time.
It seems to get stuck in gear and you need to wait for the shaft to stop spinning before you can get it into gear, also sometimes it leaps forward when you select a gear? I suppose an Over run clutxh would fix this?
Is it normal on these to have to let the pto stop before getting a gear, or is it a clutch adjsutement needed?
Used a fergy buck, good with a little bit of muscle to tip the bucket, so keeps you fit.
Been puting the blade to good use and playing arounf with the top link for different cutting grading.
PS. Is it OK to raise the slasher with the blades turning, seems bloody unsafe but only way to do it?
Cheers
Cheers
