pwr steering pump bottom fitting (to-35)
s19438
had to get a new one as the new hose would not tighten properly on the old one. now the new one will not snug up to the pump the same as the old one. it is not leaking but I am uneasy leaving it loose enough to turn it with my fingers.
any ideas on how to snug it up ???
thanks.
1.Pipe dope and or Teflon Tape
2.jamb nut for pipe thread
3. fitting may be wrong for the pump (two types of pipe fittings straight or tapered both the same thread but one is tapered) more than likely pump is straight and fitting is tapered. fitting bottoms out on flange in the pump on O ring.
