engine name plate help
hi
lost a rod bearing going to rebuild
hear what in can get off the name plate
harry ferguson
contenial
112528 1
2
011 011 20 30
dont know what the bottom & side #s are
any help thanks
What is your casting number on the block? You should see a
Z120 or Z129 number if it is a TO 20 or TO 30.
Hopefully it says Continental. I can only guess from the 112528 number it is a TO 20, but not sure. Did you look on "TOP" of the dash between the throttle lever and the hood for the tractor serial number? That usually is more important than the engine serial number. Let us know or we can not help you.
hayhay5757 that .011 .011 is the tappet clearance for the intake then the exhaust. The 20 is the recommended oil weight from the factory for winter. The 30 is the recommended oil weight for the summer.
If that 12 is on the end of the tag it should say SPEC. 12 from what I have heard that tells what went into the engine at the engine assembly plant. I do not really know what it means. Hopefully someone else will enlighten us both about the SPEC. number.
(quoted from post at 16:16:17 07/26/14) hayhay5757 that .011 .011 is the tappet clearance for the intake then the exhaust. The 20 is the recommended oil weight from the factory for winter. The 30 is the recommended oil weight for the summer.
thanks
oil pump gear split & broke a tooth / caused bearings(2) to fail
the main bearings check ok with plastic gage & are not burned
