TractorLinks.com
Show Parts for Model:
Re: Ferguson to20
miner09
07-20-2014 10:16:02
You can check the starter with jumper cables. Go from battery(tractor or your truck battery) with ground cable to frame(good ground) and hot cable from battery then touch starter post(nut) with hot cable. Be sure the TRACTOR IS NOT IN GEAR. If starter works its OK. Then look for other possible problems. Switch-Bad Cable --Ground. Or you will have a bad starter.
ajec47
07-21-2014 07:13:13
 Re: Ferguson to20 in reply to miner09, 07-20-2014 10:16:02
I have tried jumper cables and it did nothing. I took the starter off and used a battery charger and it spins fine. I put the starter back on and it does nothing. Is the starter just to weak to spin it?
ajec47
07-20-2014 15:16:56
I have tried using a battery charger and all it does is spark and smoke. Will using jumpers be any different?
