Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO30 Cylinder head studs
mathman
07-08-2014 22:55:46
Where did you find the studs?
Todd30
07-09-2014 08:25:15
 Re: TO30 Cylinder head studs in reply to mathman, 07-08-2014 22:55:46
Thanks all for the quick replies. I believe these studs are original. Can you think of a downside to using regular bolts?
Dr. Loch - what is an ARP?
Mathman - Jacks Small Engines has the new ones.
Steve@Advance
07-09-2014 20:07:12
 Re: TO30 Cylinder head studs in reply to Todd30, 07-09-2014 08:25:15
I would not use regular bolts. Couple of problems, bolts don't give the full thread depth engagement that a stud does, and a stud with a fine thread nut pulls harder than a coarse thread bolt.
Most everyone knows to run a tap in the bolt holes when going back together with an engine, which is the proper thing to do. Some assume the same is true with a stud, to run a die over the threads, especially if they're rusty. Not true! Never run a die over a bolt or stud, it will under size it. The threads are rolled on prior to heat treating. Not saying you did this, but if you did...
Copyright © 1997-2015 Yesterday's Tractor Co.
