Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
TO30 Cylinder head studs
Todd30
07-08-2014 21:39:55
75.32.202.255
Hello All, I am rebuilding a z129 engine and I keep stripping the head studs when I try to torque the nuts down (only 75 ft lbs). I found only one place that sells new ones but they"re $9 a piece. Has anyone had any luck using bolts? If so what lengths did you use? Thanks.
[Reply]   [No Email]
Todd30
07-14-2014 10:28:13
70.39.177.83
 Re: TO30 Cylinder head studs in reply to Todd30, 07-08-2014 21:39:55
Thanks all for your advice. I decided to bite the bullet and buy all new studs.
[Reply]  [No Email]
Jason S.
07-10-2014 06:19:39
174.237.46.110
 Re: TO30 Cylinder head studs in reply to s19438, 07-08-2014 21:39:55
Did you install new nuts on the old studs when you put it together? I was asking because there are different classes of tolerance fitment for nuts and bolts. Of course using the looser tolerance nuts will be more prone to stripping the studs. If you went to bolts instead of studs you would probably blow head gaskets. Bolts can not torque as evenly as studs. Basically as you torque a nut on a stud the only force against it is pulling upwards. If you torque a bolt you have two forces working against it,pulling upwards and twisting of the bolt. Did you add hardened washers under the nuts?
[Reply]  [No Email]
DrLoch
07-09-2014 16:42:14
98.26.157.221
I would use studs. When I rebuild my 23C this winter I'm going to replace the head bolts/studs with all ARP studs. Same with the rod bolts.
http://arp-bolts.com/ American Racing Products. Once you find the length and pitch you can call them to get a match. I've used there products for years in racing engines, wouldn't use anything else. Did you see the price for them @ Jack's? ARP's aren't necessarily cheap either, but you get what you pay for. They will also have the hardened nuts and washers to go with the studs.
[Reply]  [No Email]
don hooks
07-09-2014 08:01:33
99.0.60.247
Just a note on a similar experience: I was rebuilding some piece of equipment and the studs were good but I had beat up the nuts taking them off. I decided to replace them with the same grade nut from the hardware store and the same thing happened - they stripped! Turns out the new nuts were just a little larger than the originals. A case of USA studs and far eastern nuts.
[Reply]  [No Email]
DrLoch
07-09-2014 06:13:17
98.26.157.221
Thats odd, I've never stripped the threads off a stud or out of the nut and I've built a number of different motors. Are these the factory studs or have you replaced them with something else? Are you using any sort of assembly lube on the studs? If not you should be regardless of what the manual says.
When torqueing something down, there are quite a few forces involved. There is a resistive force from the friction between the surface of the bolt or stud and the object it is in contact with (block, head, cover, etc). There is, also, a resistive force coming from the stud itself as it is literally stretched (the primarly cause of the preload). There is a resistive force between the stud threads and the nut being rotated.
If everything is dry, the friction forces can be quite high. These forces effect the amount of force being put on the stud. This can and often does result in an improper preload on the bolt.
There are two different lengths used, 1 7/8″ which is part number 353964X1 and 4 11/16″ which is part number 1035877M1. They are certainly pricie..... I would try using an ARP stud and nut, they will sell individual studs and nuts if you know the thread and pitch.
This post was edited by DrLoch at 06:24:20 07/09/14.
[Reply]  [No Email]
Richard L
07-09-2014 04:45:56
24.247.143.217
Any auto parts store should have them.
[Reply]  [No Email]
mathman
07-08-2014 22:55:46
70.215.192.89
Where did you find the studs?
[Reply]  [No Email]
Todd30
07-09-2014 08:25:15
70.39.177.83
 Re: TO30 Cylinder head studs in reply to mathman, 07-08-2014 22:55:46
Thanks all for the quick replies. I believe these studs are original. Can you think of a downside to using regular bolts?
Dr. Loch - what is an ARP?
Mathman - Jacks Small Engines has the new ones.
[Reply]  [No Email]
Steve@Advance
07-09-2014 20:07:12
107.203.134.67
 Re: TO30 Cylinder head studs in reply to Todd30, 07-09-2014 08:25:15
I would not use regular bolts. Couple of problems, bolts don't give the full thread depth engagement that a stud does, and a stud with a fine thread nut pulls harder than a coarse thread bolt.
Most everyone knows to run a tap in the bolt holes when going back together with an engine, which is the proper thing to do. Some assume the same is true with a stud, to run a die over the threads, especially if they're rusty. Not true! Never run a die over a bolt or stud, it will under size it. The threads are rolled on prior to heat treating. Not saying you did this, but if you did...
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
