Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TEA20
John(UK)
07-07-2014 07:29:35
Ignition Timing could be retarded or Carburettor set too weak on Main Jet. Have you checked to see if the water is flowing through Top Hose into Radiator. The Radiator itself maybe partially blocked internally. You could try adding a gallon of vinegar and running it for a week a then drain it to see if it has loosened any crud from inside. You could remove Radiator and check to see how heavy it is, when it is furred up inside it gets quite heavy for what it is, you would need to replace Radiator or see what your Radiator Repairer says. Have you washed out the Matrix from the Engine side forward with a medium pressure hose, its surprising how much grass etc will lodge in the tubes. If you work in grass, you may need to do this as often as a couple of times a week or more in really bad conditions when there is a lot floating around in the air. If you need the Ignition and Carburettor settings, email me at the address below and I will send them to you.. John(UK).. fergusontractors@hotmail.com
Copyright © 1997-2015 Yesterday's Tractor Co.
