IAtractorKid
Dad has a TO-30 that won't stay at set throttle
speed. Will be running just fine with throttle set
then all of the sudden it will just drop a few
hundred RPMs. The throttle itself is not
moving...friction discs are new and you can have you
hand on the throttle making sure its not moving and
engine still jumps around. Is this a distributor or
governor problem? Has good power and runs strong so
im thinking worn distributor. Thanks for any and all
help!
help!
