TractorLinks.com
Show Parts for Model:
Re: Started TO-20: Rocker Assembly Oiling Question...
John(UK)
07-06-2014 04:54:02
Have you checked the oil pressure, if it is low it will cause that. If you have only run the engine at idle, that will be the reason, the oil pressure on these engines isn't very high so it will take a bit longer than you may be thinking.
If the pressure is ok then it should reach all the Rockers within a minute or so. The flow is restricted on purpose or if you had too much it would fill the Valve Cover too much and the it would get sucked down the Valve Guides.
John(UK).. fergusontractors@hotmail.com
