Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO 30 wont start
Steve@Advance
07-05-2014 19:19:22
You'll want to "load test" the starter switch. With the switch held in the start position, both terminals of the switch should have voltage.
If neither side has voltage, there is a problem ahead of the switch, like a loose battery cable, low battery, bad battery, etc.
If the battery side has voltage and the starter side doesn't, the switch is bad.
If both sides have voltage, and the starter isn't cranking, there is a problem in the starter, or the cable between the switch and starter is loose or bad.
To change the switch, remove the 4 bolts, lift the switch. Tie a wire to the linkage so it won't fall down, remove the linkage pin.
Ron in NY
07-06-2014 04:31:51
 Re: TO 30 wont start in reply to Steve@Advance, 07-05-2014 19:19:22
Thanks Steve. With the key on and the gear shift holding in the start position, I am getting only about 0.2 volts on the starter cable lug on the switch. Guess it's a bad switch. What would be the way to start the tractor until I get the switch replaced?.
Steve@Advance
07-06-2014 16:19:06
 Re: TO 30 wont start in reply to Ron in NY, 07-06-2014 04:31:51
Like John said, try to adjust it first. But if you jump across it, use an old pair of pliers of a heavy piece of wire.
Don't use a small wire!!! It will instantly turn red hot in your fingers!
John(UKI)
07-06-2014 05:00:47
There is a small amount of adjustment on these switches. If you slacken the screws securing it to the top of the Clutch Housing slightly and slide it forwards and tighten, you may find that is enough to allow it to work again. If it doesn't you need to replace the switch. They have them on this site in the parts section. To start it temporarily, you could use a jump lead from its own battery to the Starter. Just touch it on the battery terminal, don't clamp it on..John(UK).. fergusontractors@hotmail.com
Ron in NY
07-08-2014 04:56:30
 Re: TO 30 wont start in reply to John(UKI), 07-06-2014 05:00:47
Thanks guys for all the replies. To close this thread with the solution, I have to admit that it was easier than I thought. I should have paid more attention to the small spark noise I heard. I found a corroded battery connection at the start switch and also on the positive terminal on the battery. Both connections created a very low voltage under load and no start. Cleaned everything up, and now works like a champ. Sure acted like the neutral safety switch. Thanks for all the ideas.
