Tom Bowman
I started the TO-20 today, after a year and a half or so. (Starts up and runs fine, now I need to get my Local Tractor Guy to help me set idle, check the timing, make sure valves are adjusted right, etc.)
After it's been running for a few minutes, I noticed that there's a lot of oil flowing and splashing around the rear 2-3 rockers, but not so much on the ones further forward - is this normal?
I've attached a photo of the rocker assembly that I took while the engine was running, but I'm not sure that you'll be able to see too much.
I had the rocker assembly rebuilt by a company that does nothing else, so I don't have any reason to suspect that it wasn't done correctly, but...
Thanks for your help.
