Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
TO 20 transmission problem
maxazillion
07-01-2014 18:04:44
107.143.2.246
It has been awhile since I have posted to the forum. Always received a lot of good useful information here. I recently purchased a very well used TO20. Owner told me everything worked as it should. Tractor was not running at the time so like a dummy I took his word for it. Transmission does not shift into reverse. The transmission starter switch has been replaced with a starter solenoid. Is there anything that I can do to fix other than rebuild the transmission? Any suggestions would be appreciated.
[Reply]   [No Email]
Bruce(OR)
07-02-2014 17:43:48
97.115.26.109
 Re: TO 20 transmission problem in reply to maxazillion, 07-01-2014 18:04:44
Two things.
Clutch go into reverse with engine off?
Clutch might be out of adjustment.
I believe, believe I have seen a fergy shifter that the handle has to be pulled up to get into reverse. this works to keep from grinding the flywheel when pulling out of the "S" position.
I am in search of THAT shifter.
[Reply]  [No Email]
John(UKI)
07-02-2014 10:01:35
79.76.248.200
Whoever changed the Safety Switch probably couldn't find a genuine one, they were in short supply at one time and all kinds of lash ups were done. But you can get a switch easily from this site. But if it won't go into reverse, the switch is on the same selector rail as Reverse and it may just be that the Selector Rail is seized where it passes through the Transmission housing. If you remove the Transmission cover and then try moving the Reverse selector rail. you may have to clamp something onto it and try to twist it gently to free it. But won't move very much, but it may free if you try and use plenty freeing oil. If it doesn't work it will mean the tractor being split...John(UK). fergusontractors@hotmail.com
[Reply]  [No Email]
Steve@Advance
07-01-2014 18:45:14
107.203.134.67
Have you lifted the cover to see what's wrong? Could be something in the linkage.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
