Is there a full size wire loom template?
Tom H.
I am getting ready to put #3 back together and I would like to
recreate an original wire loom/bundle for this one and another
for sons #2 TO30. Does anyone have a template for this?
Thanks
I saw some posts were others had made them for their tractors
and assumed that they were able to use the original old wires.
I figure that rather then spending nearly $200 for a new set an
inexpensive set could be made using a paper template.
Here are the looms I made for the TO-30 I re-wired, I used the 2 looms, it just seemed more feasible. Also include each wire color and measurement.
Main Harness:
8 ga. red 21"
14 ga yellow 28"
14 ga brown 30"
14 ga black 37"
Generator:
14 ga green 30"
14 ga black 33"
Hope this helps.
The harness for a TO-30 is still available from Agco and it isn"t bad priced. Check these guys out for wiring harnesses. I know several people that have bought from them and the harnesses they got were top notch and came with instruction sheets. They even offer harness repair for original harnesses.
http://www.wiringharnesses.com/catalog.pdf
Thanks all will let you know if I make the sets or buy from the site you listed. Yes, their prices are a lot better than the other ones I found.
If you are making your own a trip to the local car wrecking yard is worth the trouble . You can buy a scrap wiring harness from an older car for a few dollars , in it will be just about every colour , gauge and terminal end you will need to wire up at least five tractors.
got mine from the sites listed a couple posts above. Dropped in perfect and construction was top notch. Ordered it on a Saturday and had it early that week.
