TractorLinks.com
Show Parts for Model:
Re: TO-30 bolt holding step and power take off lever
Jeremy in DE
06-16-2014 18:06:24
You can remove the side covers without draining all the fluid. Proper fluid level will be the level that it just flows out of the lowest bolt hole when it is removed.
To do the work mentioned by others you may need to drain some of the fluid. But the cover itself can be removed without draining much or any of the fluid (unless the level is too high to start with). Once off, I assume you can better determine your next course of action.
