mf 65 brake leak
bwanaclyde
New User
I have an mf 65 and transaxle fluid is leaking out from around the actuator lever boot. i thought that this model had dry brakes?
Tractors with Round Axle Housings have dry brakes, Square Axles have wet brakes. If they are dry type, then the oil must be coming from the Diff Housing...Check the Oil level in the Rear Axle first.. John(UK).. [email protected]
