Peter Nelson
New User
I'm trying to get my TO20 started for the first time in a decade. I converted it to 12 volt neg ground. Put in a new coil,wires and spark plugs, new electronic ignition. I just got my new rebuilt carb from ytmag.com today and put it on.
I have a great spark. Engage starter and I get a sputter for a second or less. Think I'll get a compression tester. I think the new rebuilt carb should be all set. No adjustments needed. Once I had a problem with a sediment bowl. There was a hair line crack in one of the lines above going into the fuel tank that caused similar problem. So close. starter fluid didn't help.
