TractorLinks.com
Show Parts for Model:
T O-35 Rust on top of top cover and lift shaft
Orlando Tangelo
06-07-2014 09:10:47
Surface rust on link shaft of my To 35 Deluxe was discovered when we went to replace the hyd pump.Is there a good way to remove this and the coat/treat the shaft from rusting again? My thought is that even with a new/rebuilt with a filter on the pump(the original one didn't have a filter} ,i ddn't want to keep havng rust get back into the fluid again and casue problems.
Steve@Advance
06-07-2014 16:40:47
 Re: T O-35 Rust on top of top cover and lift shaft in reply to Orlando Tangelo, 06-07-2014 09:10:47
Moisture accumulation in the transmission is a common, ongoing problem in those tractors. The best solution is to keep it inside, or at least under a cover. Even then expect to get some condensation.
The oil will need to be watched and changed when it begins to look milky. Might try pulling the drain plugs occasionally, best done when it's been sitting unused for awhile, see if you get water out before it gets emulsified.
Be sure the shifter boots and the boot around the top link are good.
