Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: transmission and hydraulic oil for T020
06-07-2014 03:35:21
Use Multi-grade 10W/30, this is much better all year around and definitely better in cold climates. The old GL1 Oil they used is not as good as it does not have the supplements for anti-wear that 10W/30 has. I know there are lots out there say use the old GL1 oil because that is what was used originally, but they didn't have the Multi-grade oil then. The GL1 oil that is available now is not the same "recipe" that it used to be anyway, it is more like the Multi-grade oil now but without the Multi-grade qualities. The GL1 oil does not make allowances for different temperatures like the Multi-grade oil does. With Multi-grade 10W/30 the hydraulics are much faster and they control better as the Control Valve is not being damped by the thicker oil and it is definitely better for preventing wear on the transmission. But you need to stop water getting into your system if you are changing the oil or it will go milky again. You should fit a rubber Boot to the bottom of the Gear Change Lever,(available from this site) this is the main source of water leaks and the Draft Spring at the Back of the seat is the other place but this most likely seized and requires more work to change the seal. If you need the information how to carry out this work, email me at fergusontractors at and I will send it to you and anything else that you may need. John(UK)...fergusontractors at
