TractorLinks.com
Show Parts for Model:
Re: TO 35 quitting problem
John(UKI)
06-07-2014 03:20:09
Quick check>> when it starts to die again, just pull the Choke out a little, if it is a fuel problem it will pick up again But check the fuel flow into Carb by removing drain plug at the bottom and allow fuel to run into a jug for at least 5 mins.a quick check is no use. If it seems to slow down, then maybe you do have a fuel problem, it should have a steady flow There is a filter in the elbow on the end of the fuel line that screws into the Carb. If all is OK when you test that, then suspect Coil or Condenser, cheaper to change Condenser first, these should be changed regularly. If the Points have a spike or a hole in the Contact faces, then change the Condenser as it is on its way out The Coil may get hot, but some do that anyway, if you have a similar coil from another engine you could try that if the problem persists. John(UK)...fergusontractors at hotmail.com
