George Wellman
New User
My TO 35 runs fine for awhile, but then starts to cough and miss and eventually quits. It will restart if it sets awhile. I checked plugs, all look good. It sometimes helped to add more gas. But the problem is getting worse. It seems like it is running out of gas. I did check the gas line from the tank, it supplies plenty of gas. After it has quit once, you can restart it after a few minutes and it will run at low speeds only.
So the problem probably is in the carb. Is there a filter in there that I can clean? It doesn't seem like a clogged jet problem because it only happens after it has run fine and fast for awhile.
Or could it be something else....the coil? This is a hot engine problem, runs ok until it gets hot from a cold start, it will run fine for a half hour or so.
any ideas?
any ideas?
