TO-20 Carburetor Repair Kit
Jeff Dutter
New User
I want to order a repair kit for my carb, how do I tell which carb I have on my tractor? I see that their is comprehensive kits for TSX361A or TSX458 both for TO-20's. Is it possible that I have a different carburetor than either of these?
Look at your carb there is usually a brass tag stamped with the model of that carburetor on it. Of course if your luck is like mine the last person that rebuilt it did not put it back on or he ripped it off. LOL
Thanks for the info, brass plate was still there but under some grease. I can make out TSX 36, so Can I be safe to assume I need the TSX361A repair kit?
You might also desire to keep looking for a kit that has the viton tipped float needle. That seals it better than the stock steel tip.
