Smith's combination gauge
Ark68SS
Anyone ever used one of these? They were used in older British cars like Austin-Healey and MG.
I like the idea of a 2 in 1 gauge in one opening and another gauge (probably a voltmeter) in the other opening. I was wondering if the temp gauge sender will fit without modifications. Thanks,
BillL
Interesting:
But I like to look at the gauge and see the normal
operating range to be in the center of the gauge.
Temp is that way, but oil pressure world be a bit
high for my old tractor.
They were fairly standard on a number of UK built cars, including I think the MG B?
You may find the 0 - 100 PSI gauge a bit optimistic for a Continental engine? Even the TEA20 only had a 0 - 60 PSI gauge. I prefer a more suitable range so I can actually see the needle move.
Dash on my TEA20:
Unfortunately I could not get suitable all matching white face gauges. The 30 - 0 - 30 amp meter is useless with a generator that only pushes 11 amps maximum. Lights now fitted so switch holes are now filled.
Bob in Oz
'53 TEA20
White faced gauges are available, Bob. TEAs never had an ammeter
gauge fitted, just a light with a chrome bezel....Good repros are
now available also.....In fact TEAs did not even have a temp gauge
fitted, instead there was a blanking plate over the hole, I suppose
they left it for some markets to retrofit a temp gauge if the
customer wanted one?...........Sam
When I bought my TEA20 in 1986 it had only the white oil gauge. I added the other two gauges during the restoration in the last decade.
Bob in Oz
