Engine Governor Linkage
Rocky Acres
New User
Hi Everyone!
I am putting together a TO30 I bought for a very good price. I have been having issues with the throttle creeping. I have put on a new tensions spring, and cork disc but am still having problems. I then found out I needed a compensation spring. After getting the compensation spring I realized I need yet one other part... It is #10 on the figure below but I do not know what the part is nor do I know where I can find it. Does anyone know what part this is? Any help at all would be great. Thanks!
According to your picture I am guessing you are not using a Ferguson TO 30 Parts Book as that part is #20 in my book, any way that is called Link, Compensator Spring: Part # 181 533 M1 then your number 7 is connected to it and that is 181 536 M1 and called Rocker, Governor Linkage. I am guessing your best bet to find this is a person that parts these out or a salvage yard. Others will let you know more I am sure.
I can confirm that the part number is 181533M1 and to the best of my knowledge, it is not available. I traced one out for someone else and took a picture of it so they could build one.
Rocky, run a Google search on the part number that Richard gave you, and you'll find several salvage yards that have them listed on tractor-part dot com, which is kind of a clearing-house for salvage yards.
I've dealt with several of those yards for TO-20 parts, and have been satisfied.
(There are also a few on eBay.)
Is your part just worn? You can weld holes and re-drill. Also I've seen part turned over and on top of rod. Look close. This will make a big difference.
The linkage is exactly the same on the TEA20, although I not exactly sure what that particular part does! I recently had mine apart to do some restoration and it's still working so I must have got it together the right way. On MINE, most of the time the spring is not even under tension and I can't see what action it preforms.
Leslie
Hey thank you all for your help. I found an individual who has a TO20 sitting out in a field. I am going out there today to see if this part is still on his throttle linkage. Thank you again!
(quoted from post at 10:36:25 05/30/14)
Hey, Rocky, just where is that field? Some of the rest of us might want to take a look at that TO-20! :wink:
If you can"t find one Inno sent me a scale drawing.
I cut it out of 1/4" flat stock that was out of a
old bumper bracket I used a metal cutting blade in a
jigsaw and then the bench grinder and finished it on
the belt sander. Its still working in their I have a
massey 202 with a z134 and a massey 200 loader on it
On the picture does anyone know how much tension
clamp # 6 needs to have on the spring # 5
how far towards #4 does it need to be
