TractorLinks.com
Show Parts for Model:
Re: Z134 oil pump
RonWW
05-23-2014 20:51:16
Thanks Steve. The plate does have heavy marks inside from the gears. I am hoping these do not affect pressure. The machined area that I mentioned is about a half inch by half inch, and only to the inside. It is also offset from the center a bit. I can rotate the 180* and it puts the mach area to the other side of the pump internals. If I flip it over, there would be no machine mark (not sure the beveled screw holes would let me do that anyway.).....Thanks also for verification of the rod direction. I had it right.
Steve@Advance
05-24-2014 15:42:42
 Re: Z134 oil pump in reply to RonWW, 05-23-2014 20:51:16
I wouldn't try turning the plate over. If the grooves are deep they will affect oil pressure. So will the condition of the rest of the pump...
If you feel good about the pump, you could lap the plate with 180 grit wet sand paper on a known flat surface, like a machined surface or a piece of glass.
