Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: to-35
DrLoch
05-23-2014 05:28:34
My TO-35 did have a suction filter/strainer on the inlet of the pump. Doesn't do much other than make sure no big trash get pulled into the pump. The way I see it the only way to change or clean that filter is to lift the cover. A person may be able to access it if you were to pull the left access cover and lever.
Steve@Advance
05-23-2014 15:17:43
 Re: to-35 in reply to DrLoch, 05-23-2014 05:28:34
Yes, those pumps have been changed several times, have to do a serial # search to see which one is supposed to be in there. Think mine is a 59 or 60 model. It didn't have any screen, didn't see any place for one, wish it did.
brian stanek
05-24-2014 08:59:59
 Re: to-35 in reply to Steve@Advance, 05-23-2014 15:17:43
Quoting Removed, click Modern View to see am i correct in assuming both the trans and rear axle use the same oil? in cleaning out the sump containing the pump i have not noticed a common transfer port.
Steve@Advance
05-24-2014 19:11:03
 Re: to-35 in reply to brian stanek, 05-24-2014 08:59:59
Yes, it's all the same gearcase. It will hold about 8 gallons, but pour it in slowly. It takes a while to level out betwene the transmission and and rear housing. Don't want to fill the transmission too fast, if the front seal is bad, it will dump oil on the clutch!
