Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
to-35
brian stanek
05-22-2014 16:45:19
204.237.89.176
my manual talks about 50wt oil for tranny and diff. is 15/40 fine or what may be correct? i pressume both take the sam oil. thanks for any info.
[Reply]   [No Email]
Steve@Advance
05-22-2014 20:10:32
107.203.134.67
 Re: to-35 in reply to brian stanek, 05-22-2014 16:45:19
Expect a lot of different opinions on this subject...
Here's my take.
The 50w engine oil is the equivalent to 90w gear oil. This gives good wear protection, especially if you're working the drive train hard in warm weather. Since the manual was written there have been improvements in additives. The GL4 90w gear oil is a popular one, has EP additives, better wear protection than engine oil.
The down side to using the heavy oil is slow lift performance in cold weather. If you're in a warm climate or don't use the tractor in cold weather, the heavy oil is fine.
For cold weather use, many like 10w30 motor oil. Your choice of 15w40 would be close enough. There is also a Universal Tractor oil at Tractor Supply that is in the same range.
So, a lot depends on how the tractor is used, the temperature range, and your personal preference. I don't think what you choose is as important as keeping it clean and dry. These are notorious for collecting water. It gets in around the shifter boots, the rear top link boot, and condensation. And, there is no hydraulic filter, so whatever is in the transmission gets run through the hydraulic system too!
[Reply]  [No Email]
DrLoch
05-23-2014 05:28:34
96.10.233.18
 Re: to-35 in reply to Steve@Advance, 05-22-2014 20:10:32
My TO-35 did have a suction filter/strainer on the inlet of the pump. Doesn't do much other than make sure no big trash get pulled into the pump. The way I see it the only way to change or clean that filter is to lift the cover. A person may be able to access it if you were to pull the left access cover and lever.
[Reply]  [No Email]
Steve@Advance
05-23-2014 15:17:43
108.245.66.82
 Re: to-35 in reply to DrLoch, 05-23-2014 05:28:34
Yes, those pumps have been changed several times, have to do a serial # search to see which one is supposed to be in there. Think mine is a 59 or 60 model. It didn't have any screen, didn't see any place for one, wish it did.
[Reply]  [No Email]
brian stanek
05-24-2014 08:59:59
204.237.89.176
 Re: to-35 in reply to Steve@Advance, 05-23-2014 15:17:43
Quoting Removed, click Modern View to see am i correct in assuming both the trans and rear axle use the same oil? in cleaning out the sump containing the pump i have not noticed a common transfer port.
[Reply]  [No Email]
Steve@Advance
05-24-2014 19:11:03
107.203.134.67
 Re: to-35 in reply to brian stanek, 05-24-2014 08:59:59
Yes, it's all the same gearcase. It will hold about 8 gallons, but pour it in slowly. It takes a while to level out betwene the transmission and and rear housing. Don't want to fill the transmission too fast, if the front seal is bad, it will dump oil on the clutch!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
