Peter Nelson
New User
So I have this TO20 im fixing up that hasn't ran in years. I've converted it to a 12 volt negative ground, Replaced the coil. Got an electronic ignition. I'm 99% sure I wired it correct. I have another exact tractor that I rewired years ago to reference too. I'm reading roughly 9.85 volts going in and out of the coil, but no spark going to distributor. I did it in the dark.
When I measured the resistance of the coil from + to - I got 4.1 ohms. Ignition to - or + I measured 9.75 kilo ohms. I also made sure timing was O.K. Which I think it is. Did I get a vaulty coil. Maybe the Distributor is bad.(the only original part left)
