Joel Simon
New User
I have a 1954 TO-30 that I just got running. The
lift arms will not move and the hydraulic fluid
looks like...... a milk shake. I plan on running,
without load to warm the milk shake oil and then
draining it. I will then put in some cheaper oil
with sea foam and run without load again and
drain. I will then put in GL-1 90 mineral gear
oil. The top link spring is loose enough that I
am able to spin it. I was wondering what
maintenance I should perform while the rear end is
empty. I already know of the PTO oil seal. I
will inspect the lift arm control linkage after
opening but that is all I am aware of. I know
that there are o-rings in the hydraulic pump but
with the lift arms not even lifting I don't
suspect that to be the problem. I wish to get
this tractor operational for this summer and plan
on a tear down, repair, and paint job this coming
winter. Any transmission/hydraulic internal
maintenance/repair suggestions would be very much
appreciated.
appreciated.
