I started a thread about my neighbors TO20 lift issues and now today I have one of my own. I was pulling a box blade with the ripper teeth down and apparently hooked a root while I was lifting it. It went (jumped) up and I can't lower it with the adjustment handle. It is drifting down slowly though. I've removed the side cover and it appears that the control lever mechanism isn't connected or the control valve is stuck in the up position. If that is the problem what is the best method of getting unstuck? The MF14 manual I have is about useless. If there a better manual for this model? I ran into the same thing when I was working on the motor. The way I'm going I may be able to write my own manual by the time I'm through.
