TO-20 Converted to 12-Volt - Dumb Question...
This will vividly illustrate my lack of knowledge about tractor electrical systems, but here goes.
My TO-20 had previously been converted to 12-volt, negative ground, with what I think is a one-wire alternator. (It only has one wire running to it, anyway.)
I won't be changing any of the electrical stuff, but I've had the battery, alternator, starter, etc. all unhooked for a long time.
I've read about polarizing a [i:3328af1cd9]generator[/i:3328af1cd9], but do I have to polarize an [i:3328af1cd9]alternator[/i:3328af1cd9]?
No, you do not need to do anything but start it up. Alternators
are self exciting and to the correct polarity. If you have not
changed over to a 12volt coil you will need a resistor to bring
the voltage down to 6volts though.
No, but you may have to "rev" the motor up pretty fast to get that one-wire alternator to start charging. Some of the one-wires are built to self-excite at a relatively slow speed - some are not. Either way, once it starts charging, both will charge at slow motor speeds.
Thanks, Tom and Hills.
Just to clarify, I didn't do the 12-volt conversion; it had already been done when I bought the tractor at auction a couple of years ago.
I don't know what the voltage of the coil is, but the tractor started and ran fine, and the battery charged.
Should I be able to find markings on the coil? (It looks pretty old.)
