tire pressure
Anonymous-0
just put new tube in rear tire 12.4--28 just use it to finish mow with no water or liquid in it just wondering how much to guage tire to thinking about 15 lbs. thanks
Usually between 9-14 lbs where I live, depends on the job you are doing and the load you are carrying!............Sam
I was running 18 psi, being that the tire print on the side said not to go over 35 psi so 18 is near half, but it less pressure will make a nicer ride
