Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: more on the 35
Steve@Advance
04-06-2014 13:41:05
The thermostat will stop the movement of water through the radiator until the engine is up to temp.
It will then slowly allow the heated coolant to move through the radiator. If you feel warm air being drawn off the radiator by the fan, then it is circulating.
s19438
04-06-2014 13:49:05
 Re: more on the 35 in reply to Steve@Advance, 04-06-2014 13:41:05
after a few minutes of running the top of radiator gets hot but looking into the rad. I cannot see the water moving. the water pump seems to be working fine. quiet as a mouse.(almost)
Steve@Advance
04-06-2014 20:59:32
 Re: more on the 35 in reply to s19438, 04-06-2014 13:49:05
You may not be able to see the water moving. As long as the engine is not overheating nothing to worry about.
It's very rare to have a water pump fail to pump. They may leak, have bearing failure, but still pump. Only if the impeller falls off will they stop pumping, extremely unlikely.
It's possible the radiator is clogged, but that would be indicated by overheating under heavy load. Again, the air coming through would be cold when the engine was hot.
