Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: vertical exhaust picture
Bob (Aust)
04-05-2014 15:03:02
"It had a hole in the manifold at about the same place as that tube on the outside of you manifold about in the center of the manifold. What is that tube for??"
That is the breather pipe from the valve rocker cover.
"What is the purpose of the little tube at the top of the filter close to the big carb intake tube. Is it for crankcase ventilation?"
That is a lower end crank case breather.
Whilst I'm posting .......... a TEA20 generator output is only 11 amps maximum. The only 2 inch matching amp meter I can find is 60 - 0 - 60, so when generating the needle hardly moves at all.
Anyone know where I can buy a 2 inch -15 - 0 - +15 amp meter with either black or white face?
Thanks
Bob in Oz
'53 TEA20
This post was edited by Bob (Aust) at 15:06:16 04/05/14.
Bart CA
04-06-2014 10:14:49
 Re: vertical exhaust picture in reply to Bob (Aust), 04-05-2014 15:03:02
Try this link
http://v2.ca-en.sparex.com/ItemDetails/ItemDetails.aspx?ItemNumber=4340&SingleResultCriteria=
HTH
Bart
Bart CA
04-06-2014 09:58:22
Thanks Bob for your reply....
Ampmeter: I found a reproduction meter at Sparex
few years ago. Orderred via local Sparex distributor. I do'nt know if they are still available.
Thanks again
Bart
Charles in Aus.
04-06-2014 01:41:18
I will send you a link to a black one Bob .
Copyright © 1997-2015 Yesterday's Tractor Co.
