Question on how the Ferguson tractor Jack works.
I know it lifts the tractor up off the ground when you raise the lift.
But, say now you are widing the rear tires and front end. My old Ferguson TO35 lift will gradually go down in a while with a load left on it in the raised position.
You could not afford for the lift to go down while you are turning around the rear wheels or adjusting the spacing of the front end.
What insures the lift stays up while you are doing your work??????
