Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: TO-35 no oil to rocker arms
04-03-2014 08:11:23
Oil to the shaft is supplied through the rear shaft stand, comes up through an oil port in the head.
Loosen the rocker shaft bolts just enough for the rear support to raise off the head. Start the engine and see if oil comes out under the stand. If it does, the oil hole in the rocker shaft is clogged or the shaft was assembled wrong.
If no oil comes up through the head the rear main may have spun or something is wrong in the lower end of the engine.
Since the rockers have run dry, the bushings and shaft are probably bad. The shaft and bushings can be bought, but the bushings will need to be reamed to fit the shaft. Much easier to buy a rebuilt shaft/rocker assy.
Jack in Wyo.
04-03-2014 21:23:04
 Re: TO-35 no oil to rocker arms in reply to Steve@Advance, 04-03-2014 08:11:23
Thanks, I loosened the rocker shaft bolts enough to get a small gap under the rear support and still got no oil with the engine running.
Tomorrow I will drop the pan and check the rear main. I may have more questions after that.-Thanks
Jack in Wyo.
04-04-2014 17:25:27
 Re: TO-35 no oil to rocker arms in reply to Jack in Wyo., 04-03-2014 21:23:04
OK, today I took off the rear main bearing cap and removed the bearings. They are marked upper and lower and they were in wrong. The one marked upper was on the bottom and the one marked lower was on top. So I assume that was the problem. The hole pattern is very different between them. They are marked .020 so are oversized. Should I just get a new set of .020 oversize and put it back together the right way? The crankshaft journal looks fine.
04-04-2014 19:40:37
 Re: TO-35 no oil to rocker arms in reply to Jack in Wyo., 04-04-2014 17:25:27
If the bearings look good, as in no galling or overheating, they can be put back in. Are the lock tabs ok? They may have been flattened by installing them wrong, something to look at, they could be bent back.
I would remove the other main caps and be sure they are in right. Might take a look at the rod bearings, they may have not been oiling either. Make sure the rod caps are on right, the bearing lock tabs go both on the same side.
At least now you've found the problem, just hope nothing is damaged!
Jack in wyo
04-05-2014 13:12:56
 Re: TO-35 no oil to rocker arms in reply to Steve@Advance, 04-04-2014 19:40:37
Thanks for the ideas. The bearings are a little galled and there are some flakes in the grooves so I plan on replacing them. Good idea I will check them all even the rods.
