TO20 need help find part
Hi all, I have a 1946 furgeson TO20. i recently had both viewing plates off as i was upgrading my pto shaft and changing all the fluid. As i was putting on the viewing plate opposite the plate with the pto lever. I was tightening down the fitting were the hydrualic line attaches and i broke it off. can anybody help or have any info as to what that is called or where i can find one? I have been to all my local dealers here and cant seem to get anywhere one it. Any help would be appreciated. Thanks
The OEM TO-20 doesn't have a hydraulic fitting on that access plate. The OEM plate has a dip stick holder and dipstick. You must have a set up that is using that plate for a hydraulic return line. If that's so, then most likely a regular hydraulic fitting was used. Take the remains of the fitting to a hydraulic equipment supplier and they may be able to help.
Does it look something like this?
Arend you may want to check your serial number again as there were no TO 20s made until 1948. The TE 20s were made in 1946. The TO 20s were all basically the same it is just that you want to know the correct year.
