MF35 with Perkins question
Dan S (NY)
Can anyone tell me where the spring on the fuel shutoff rod hooks to on the tractor? When I bought this MF35 Perkins, there was no fuel shutoff rod at all so I am installing one. The parts book shows a spring that hooks to the rod but does not show where the other end goes, nor does it indicate how long of a spring it is. Can't find pictures on the web that are close enough to that area to tell either.
Thanks,
Dan
don't no much about diesel engines but isn't that the only way to shut them down elec. fuel pump or manually?
Yes, you shut the fuel off at the injector pump. You had to get off the tractor and move the lever at the pump to shut this 35 off when I bought it and I like to be able to do that from the seat in case of an emergency.
Dan
Found a hole under some dirt down under the battery platform and it looks like the spring fits pretty good there.
Dan
