TractorLinks.com
Show Parts for Model:
Re: TO-35 front axle replacement
wkndwrnch
04-01-2014 17:27:33
I intend to keep the original axle, as it may be repairable.
Bruce(OR)
04-01-2014 17:45:54
 Re: TO-35 front axle replacement in reply to wkndwrnch, 04-01-2014 17:27:33
Okay. To repair the front axle back yard style you need an old oven with the broiler working. Obtain diamond plate steel, about 3/8 thickness. Cut into shape to fit into rear of front axle recesses. Punch a hole in both sides of the oven. Insert axle heat to highest temp possible. Weld with nickel rod. Allow to drop 100 degrees in temp per hour. This is possibly best done with a virgin axle as I had done by a buddy. Precracked is preweakened. Chinese cast iron is a lot more porous. Porosity tends to leak to weakness.
wkndwrnch
04-02-2014 03:56:05
 Re: TO-35 front axle replacement in reply to Bruce(OR), 04-01-2014 17:45:54
Bruce, thanks for response. I did not mean to start a sidetrack. I will replace front axle with a new one. I want to have tractor back up and running.I have a hard time throwing all things away, so I will see about repairing old axle.(I can always bring in a load to metal recycling place)I was more asking about removing loader to get access to front axle, but after spending some time last night,it seems possible,that will be my first plan. Plans can change!
