Picked up an offset Howard Rotavator today. Wheel
adjuster is frozen and I beleve the engaging gear
box is in need of repair of some sort.
This tiller bolts onto the rear end of the fergys
and fords with the 1-1/8" PTO shaft. Support bracket
bolts around the left fender mount. This tiller has
an engagemnet rod that keeps the blades from turning
until the operator desires. So with the typical PTO
of the era you can raise/lower the tiller without
needing to have the blades turning.
The question is stirring in the back of mind as to keeping this toy or not. Hmmm.
