hey all I need to know asap ,the rear outside hub assembly that holds the bearing on a ford 8 n , 9 n ,or any other N going to fit this Ferguson to 30,i am changing outer seals, the other question is does Ferguson paint there hubs Red ?
well what is going on is I took my rear hub to a machine shop & he did the first 1 ok , I had already cut the axle collar off,the second 1 he wanted the collar left on , so I left it on ,I pick the axle up & go to put it on , it won't go on ,I took all but 1 stud out & the backing plate doesn't even go on the red hub, so is this a red Ferguson hub or a trying to pull wool over the eyes Ford red hub ,
so what color are the Ferguson hubs suppose to be ? I did not take pics of hub when I tookit off, thanks ,
